Old 05-11-2008   #1
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Skate Boarder Champion
Question 1242 coolant temp sensor resistance
Can anyone tell me what resistance readings i should get from the coolant temp sensor (blue one on inlet manifold) @ 20degrees and 60degrees.
I've got one out a 1108 thats reading 450ohms @ 60degrees and 3000ohms @ 20degrees, which is way diferent to what it says they should be in my haynes. Which states 5ohms @ 60degrees and 5000ohms at 20degrees.
Also are the sensors the same on both the 1108 and 1242??
Finn: Panda 100HP
Oberyn: Suzuki Ignis Sport
Urchin: Alfa 159 SW
PEX: Cinq Track Car
Some previous cars: Bravo HGT, Cinq 16v, Sei Turbo, Punto GT, Panda Mania 1242 mpi
blu73 is offline Reply With Quote Quote
Old 05-11-2008   #2
arc
this is where i stand
arc has donated!
Re: 1242 coolant temp sensor resistance
iirc they should be the same mate.
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 05-11-2008   #3
kritip's Avatar
Trader Rating: 4
kritip has donated!
I have posted the tech data sheet in the MS thread
kritip is offline Reply With Quote Quote
Old 06-11-2008   #4
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
OK, defo got the right one now. Ta.
Cars still not sorted, will update soon, got few more things to try before more questions
edit: is the MAP sensor the same 1108 to 1242?? or is it easier to ask if there any that are different.
Finn: Panda 100HP
Urchin: Alfa 159 SW
PEX: Cinq Track Car
Old 06-11-2008   #5
arc
arc has donated!
same, same on the 899 too
Thanks blu73 thanked for this post
(G) coolant temp sensor ? csi_mon Cinquecento / Seicento 7 08-02-2008 14:39
(T) Resistance of Ignition coils on 2000 punto 1242 andrewb Punto (Mk2/2b) 1 11-05-2007 21:52
(T) coolant temp sensor khanny Bravo / Brava 8 17-11-2005 10:51
(T) Temp sensor=Temp gauge sensor? CphFiat Punto (Mk1) 2 27-11-2003 18:13
(G) Sensor resistance gtomas Tipo (Classic) 2 15-11-2003 05:36
