Can anyone tell me what resistance readings i should get from the coolant temp sensor (blue one on inlet manifold) @ 20degrees and 60degrees.
I've got one out a 1108 thats reading 450ohms @ 60degrees and 3000ohms @ 20degrees, which is way diferent to what it says they should be in my haynes. Which states 5ohms @ 60degrees and 5000ohms at 20degrees.
Also are the sensors the same on both the 1108 and 1242??
