im Axle Specialists
Thread Tools
Old 04-11-2008   #1
which mount
hi,which mount is this ,a engine or gearbox.its a seicento sporting.cheers
[IMG]
http://i295.photobucket.com/albums/mm154/needspeed33/100_0637.jpg[/IMG]
ID:	52795   Click image for larger version
ID:	52797   Click image for larger version
needspeed is offline Reply With Quote Quote
Old 04-11-2008   #2
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: which mount
Its on the gearbox, but is usually refered to as the rear engine mount.
PD
Old 04-11-2008   #3
Re: which mount
i,ve asked my local fiat dealer for a bottom engine mount,is this right.cheers
Old 04-11-2008   #4
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Re: which mount
Quote Originally Posted by needspeed View Post
Should do, did he not show you it on eper?
PD
Old 04-11-2008   #5
Re: which mount
no, ordered it over phone.is this part easy to fit,is it just acase of unbolting it and refit.cheers
Old 04-11-2008   #6
Trader Rating: 5
fingers99 has donated!
Re: which mount
Easy to fit -- about 20 minutes. Getting a jack underneath to hold up the gearbox helps. Shiney side up.
fingers99 is offline Reply With Quote Quote
Old 04-11-2008   #7
Re: which mount
cheers mate
Old 04-11-2008   #8
Re: which mount
I have replaced both rear mount and gearbox end mounts , can be fiddly, a trolley jack would help, i did not remove the 2 bolts on the bracket when i replaced the rear mount, i think doing this will make it much easier to do so it may be the way to go, good luck. ps it's worth checking the condition of the gearbox mount it may be split(this is located just above the nearside wheel within the wheel arch), mine was split but the rear mount was fine.
marino is offline Reply With Quote Quote
Old 11-11-2008   #9
Re: which mount
hi, i been trying to change this mount today as in above pics.i can undo the 2 bolts with hold the mount to the underside of the car,but can't undo the bolt in the middle of the mount.it just turns alittle bit then the rubber mount just starts flexing under the pressure of turning the bolt.any ideas.
cheers
Old 11-11-2008   #10
Trader Rating: 5
Re: which mount
Take the whole bracket off, then you'll be able to get at both nut and bolt. Remember, shiney side up!
Old 11-11-2008   #11
Trader Rating: 1
Re: which mount
or take the top bolt out of the bracket, swing the bracket down and then you can get to it....1 less bolt to undo if your lazy
Brooky is offline Reply With Quote Quote
Old 11-11-2008   #12
Put a towl on it
willieboy's Avatar
willieboy has donated!
Re: which mount
Quote Originally Posted by Brooky View Post
i like your style
Quote Originally Posted by Daz_Rich View Post
i look like a 14 year old with a food eating problem
willieboy is offline Reply With Quote Quote
Thread Tools
(G) gearbox mount rallycinq Cinquecento / Seicento 4 28-03-2010 20:57
(G) 2.4 Engine Mount Greggers Stilo 1 17-07-2008 14:23
Dash mount/Window mount for a digicam? Skate2create Leisure Lounge 8 31-01-2007 17:53
(G) Engine mount stonecold128 Panda (Classic) 2 15-12-2006 23:47
(T) engine mount LanciaMad Cinquecento / Seicento 2 11-09-2006 14:30
