General which mount
General which mount
needspeed
plymouth
hi,which mount is this ,a engine or gearbox.its a seicento sporting.cheers
no, ordered it over phone.is this part easy to fit,is it just acase of unbolting it and refit.cheers
I have replaced both rear mount and gearbox end mounts , can be fiddly, a trolley jack would help, i did not remove the 2 bolts on the bracket when i replaced the rear mount, i think doing this will make it much easier to do so it may be the way to go, good luck. ps it's worth checking the condition of the gearbox mount it may be split(this is located just above the nearside wheel within the wheel arch), mine was split but the rear mount was fine.
hi, i been trying to change this mount today as in above pics.i can undo the 2 bolts with hold the mount to the underside of the car,but can't :mad:undo the bolt in the middle of the mount.it just turns alittle bit then the rubber mount just starts flexing under the pressure of turning the bolt.any ideas.
cheers:)
