bsafirebird
- Jul 9, 2008
- 21
- 7
I'm baffled... I have changed the antifreeze and then bled the system, no probs with the lower bleed point but the upper one is causing some bafflement. After a while I got the heater working OK and my plan was run it up to temp and use the pressure in the system to carefully bled the upper point. So i gingerly undid the upper bleed screw expecting air then coolant out but there's nothing. Surely the whole system is under some pressure. I even dibbled water down the tube revved the engine and nothing happened? does the bleed tube suffer from blockages or does it just never bleed the air????
