Old 03-10-2008   #1
1.4 16v running 1.2 inlet with 1.4 injectors,wierd running. help !
i know a 1.4 16v isnt a cinq or sei engine.
but you guys love them and see to put them into cars and mess around with them lots.
so heres a problem for you ...
in my old style panda i have just put a 1.4 16v superfire
(had a 1.2 16v turbo b4(things broke))
iv added 6spd box and other stuff.
im running the engine on a mk1 1242 16v punto inlet and throttle
and using all the 1.2 16v punto wiring loom
i have put the 1.4 injectors into the 1.2 fuel rail.
it starts fine
everything seems good. but when you rev it it has a juddery delay before the revs pick up.
i went for a very small test drive this morn.
as i pulled out it stuttered loads and then it kicked into action and i wheel spun all over the place, and then it did the same as i went into 2nd.
any suggestions.
should i check the timing is right ??
tick over is also a little low when its warmed up. but it doesnt stall.
the exhaust is all 2" , with a 4.2.1 manifold and a small fairly well flowing cat and one very flowing backbox .
could it be throttle body too small ?
timing out ?
exhaust pressure ?
please do your usual magic and help guys. !!
thanks massivly in advance !
aran.
Current owner of a ----------Creator of a beasty
40mm lower COLOUR---------- 1242cc white 4x4
Xsisley is offline Reply With Quote Quote
Old 03-10-2008   #2
Re: 1.4 16v running 1.2 inlet with 1.4 injectors,wierd running. help !
could it be crank sensor placement ?
i used the 1242 16v crank pulley and sensor with that wiring loom.
and i thought both the 16vs had the same oil pump/sensor position. ??
there is no probs with the alt belt and panda mount.
aran.
Old 03-10-2008   #3
arc
this is where i stand
arc has donated!
what is your fuel pressure like, are you using a rising rate regulator?
the 'bogging' down when you accelerate could be a sharp lack of fuel, my car does that if i tune the acceleration enrichment too low (or too high as well for that matter!)
try removing the vacuum hose that runs to the fuel pressure regulator (but cap the tube else the MAP sensor will get upset) and see what it does
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 03-10-2008   #4
kritip's Avatar
Trader Rating: 4
kritip has donated!
what ecu is it, the 1.2 16V?
Crank sensor placement is the same so that isn't an issue.
has the ECU been remapped?
As arc said, whats your fuel setup? Did you keep the return line, or are you runnign a non-return setup? If its a return setup, is the pump good enough?
I'd be looking more at ecu issues though.
Exhaust should be fine. My 1.4 runs a SS 4-2-1, with a two inch bore and flows even freeer than yours if you get my meaning.
Does it do this warm and cold?
do any warning lights come on?
If its a 1.2 16V inlet, there is no map tube its built into the inlet temp unit
Bogging down can also be too MUCH fuel as well.
You MAY need to recalibrate the TPS.
The wheel spin may be normal, i can spin mine up and my wheels are 6" wide with some good rubber on. If you have standard panda wheels, then When i had the 1.2 16v in, the 13" sei alloys with pirelli rubber were lethal!
Lots of ideas and lots of questions
kritip is offline Reply With Quote Quote
Old 03-10-2008   #5
ok the ecu is the 1.2 16v one.(standard)
i have got a return pipe to the tank.
and i have bodged the 1.2 16v fuel pump into the tank.
(worked ok on the 1.2 16v turbo)
i rekon its fuelling somewhere
i will play with the pressure regulator pressure pipe. and maybe block the return for an experiment ???
thanks for help guys !
will go play !
Old 03-10-2008   #6
arc
arc has donated!
no worries, good luck
I wouldn't block the return though.. pressure will go through the roof
Old 04-10-2008   #7
kritip's Avatar
Trader Rating: 4
kritip has donated!
yeah, only block the return if you run a pump that returns to the tank like some of th emodern ones do, kike the 1.4's and my 1.1 mpi sei pump.
Why did you ditch the 1.2 tub?
Kristian
Old 04-10-2008   #8
J333EVO has donated!
I think its the injectors at fault, well not so much the injectors but how you are driving them.
The 1242cc engine uses older style injectors, whereas on the 1368cc engine it uses more modern piezo type injectors, so the duty cycle/duration etc will be very different from the 1242cc injectors. I do not know but you may even find the resistance on the injectors is different, it can be problem when trying to run injectors from different cars on your own, the Cosworth and integrale although running same ECU run different resistance rate injectors.
Therefore the way your 1242cc ECU is trying to run the newer style injectors is not compatible.
I would try some 1242cc injectors and see what happens, I would say that the engine would run as it should without the cutting out/hesitation you are experiencing, but it would still be preferable to get the fuelling checked on a r/r to ensure its all OK.
For the record as we use a 1242cc inlet manifold on our 1368cc engine we used Bosch black injectors (older style) from a MG Maestro IIRC.
Cinquecento Abarth 1.4 16V 6speed track toy
Lancia integrale EVO1 Homologation model
MINI Clubman Hampton Edition Cooper SD
VW MK5 Golf R32
J333EVO is offline Reply With Quote Quote
Old 04-10-2008   #9
Trader Rating: 10
dave has donated!
Quote Originally Posted by J333EVO View Post
should i be using 1.2 injectors too then?
“The further a society drifts from the truth, the more it will hate those that speak it.”
Old 04-10-2008   #10
kritip's Avatar
Trader Rating: 4
kritip has donated!
I can happily run the two different injectors, but i do need to adjust the pulse width to correct the afr. On the stock ecu, it would probably need a remap to correct it, but i think using the injectors after that should be fine. they are the same resistance
I ran the 1.1 mpi unmapped ecu with 1.2 16v engine and injectors fine as well.
Still worth a try swapping them, I think they should still run the eninge, but at least check the afr isn't too lean before giving it some stick.
Kristian
Old 04-10-2008   #11
Trader Rating: 10
dave has donated!
ah mine got mapped, oggy was about 2 hours sitting at the desk writting my map, an fuel line was spot on, so i should be ok then?
Old 04-10-2008   #12
kritip's Avatar
Trader Rating: 4
kritip has donated!
yep, no probs. The injectors have a lot of head room, and can potentially provide a lot more fuel that they do. My 1.4 injectors don't normally see abouve 45-50% duty cycle, and they can be drive up to 80% all day long with no issues
Thanks dave thanked for this post
Old 04-10-2008   #13
On my old cinque i did have a similar problem but the injector light came on only when i reved past 5500rpm had it on diagnostic and came up as injector fault so i used punto gt injectors which i already had which are too big but turned down the fuel pressure a bit think 2bar and it run fine then the day after i turbod it and got a whole new set of problems
98Seicento 1242mpi turbo
97 Cinquecento sporting (too narrow)
99civic aero deck '1.8vti-too wide'
95Nissan primera 2.0eGT
Slosei is offline Reply With Quote Quote
Old 07-10-2008   #14
hmm so i should play with injectors..
i am going to double chek the timiing on the belt.
just becuase it wud be annoying if i found it was one notch out later on
after play with fueling.
so do we all think it would run ok with the 1.2 16v injectors ????
no too lean. the ecu should sort AFR out ??
sounds like somthing worth a try.
arc, i did block the return. the pressure didnt go through the roof.
it poped the blockage and went all over the engine bay, hahaha
no harm done.
thanks guys VVVV helpful !
Old 07-10-2008   #15
just checked the timing !
its fine.
so its gotta be a fuel or ignition kinda thing !
iv stripped the manifold off and will go try the 1242cc injectors in a sec.
then if that works better i will try get some of the MG Maestro ones. sounds good.
thanks guys !!
aran.
(T) bravo 1.6 16v not running good robfal Bravo / Brava 4 26-04-2007 09:39
(T) running problem with 16v punto rickie p Punto (Mk2/2b) 3 03-10-2005 12:42
(T) Fiat Tipo 2.0 16v inlet manifold and fuel rail with injectors for sale! tododelado Tipo (Classic) 0 04-05-2005 00:11
(T) 1.8 16V running cold. svendp Coupe 6 23-04-2002 12:59
