Hi, I have a coolant leak which drips from the front bulkhead, directly below the heater matrix. Currently its only 1/4 egg cup per day. I guess its the heater cock/valve or matrix itself. It makes no difference if the dash dial is set to hot or cold. The bad news is that this car has air conditioning (not worked for years). Anyone know if the valve and/or matrix can be replaced without removing the entire heater/air conditioner box assembly. Also, is it safe to just disconnect the a/c pipes without having the system de-gassed. I don't really care if the a/c never works and have a mind to remove it all together, pump, radiator, pipes and all.
Nick
Nick
