im Axle Specialists
Old 20-08-2008   #1
seicento not firing on 2 and 3 cylinder
Just got a 2001 Y reg seicento 1108cc SX sporting, wasnt firing on 2 and 3 cylinder so changed both coils, when i remove the wiring harness going to the front coil controlling 2 and 3 cylinder when idling nothing changed the idle speed when i disconnect the second coil further away controlling 1 and 4 cylinder it stalls thus 2 and 3 not firing although it is sparking just changed plugs and leads and waiting to test again - anybody experienced same problem and know what it might be???
nokiaman2002 is offline Reply With Quote Quote
Old 20-08-2008   #2
arc
this is where i stand
arc has donated!
Re: seicento not firing on 2 and 3 cylinder
welcome to the forum.
if you've lost two cylinders both connected to the one coil pack then its quite safe to assume the fault is the coil pack - but should be tested first by swapping the wiring harness connections over, and the HT leads. So the rear coil is controlling 2 and 3.
are you saying you've replaced both coils and the fault is still there? Could be an ECU fault, or fault on the cable for the front coil pack.
Thanks ycming thanked for this post
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 20-08-2008   #3
yes thats right 2 new coils new plugs and leads but get this - when i put the injector wiring from the working 1 and 4 cylinders onto 2 and 3 cylinders they fire up! maybe i should reset the ECU as they are 2 new coil packs
Quote Originally Posted by arc View Post
Old 20-08-2008   #4
oh and to make things more interesting the front coil pack which i suspect of being faulty does spark to the leads! does the ecu need resetting do you think and how do i go about it
Old 21-08-2008   #5
Bring On The Trumpets!
ronnieronson's Avatar
ronnieronson has donated!
Quote Originally Posted by nokiaman2002 View Post
Not sure if an ecu reset will cure it, but here goes:
Disconnect the negative battary lead.
Leave it unplugged for about 20mins (some people suggest longer, but I've found 20 mins to be sufficient).
Reconnect.
ronnieronson is offline Reply With Quote Quote
Old 21-08-2008   #6
Trader Rating: 5
fingers99 has donated!
Can't see it being the ECU: that would surely produce the same effects with boring regularity. I suspect a wiring fault. Might be worthwhile trying a single jump lead to points of the engine close to the coil pack from the batt negative. See if owt remarkable happpens.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 21-08-2008   #7
Trader Rating: 1
craigb244 has donated!
spankthemonkey Champion
yeh you need a multimeter and a manual then check continuity between the connector to the coil pack that that dont fire and the ECU plug.
If my manual was here I would give you the ecu plug, pin number
1997 - White - Cinquecento - PPC featured High boost 16v Turbo
2010 - White - Punto evo GP
craigb244 is offline Reply With Quote Quote
Old 21-08-2008   #8
ok well ecu reset didnt do anything eng management light still on.if i diconnect the injector yellow plugs fron the firing 1 and 4 cylinders and place them on 2and 3 they fire on 2 and 3 then.if head had gone between these two then they wouldnt fire.time for some more digging i think
Old 21-08-2008   #9
Trader Rating: 5
So it had naff all to do with the coils in the first place? It's a wiring fault....... probably.
M12 fund 20
Old 21-08-2008   #10
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Remember its the return thats switched, not the supply.
PD
Old 21-08-2008   #11
sorry just explain that one?seems to b something on the cylinder 2 and 3 coil but not the coil.never had anything like this before
Old 21-08-2008   #12
Autotest Special
rallycinq's Avatar
Trader Rating: 1
The coils have a permanent live supply once the main relay is energised by switching on the ignition.
The ECU controls the negative side of the coil. So you should see a supply to the coils with the ignition on.
PD
Old 22-08-2008   #13
is there a different relay for each coil or just one relay? if so where are they located, are they under the screw-off plate at top right hand side of engine bay as you look at it? 2 red relays one is cooling fan relay i know that - further more my mate took a look tonight as i was working and found one lead to be sparking like hell and shorting out - they are new leads too! keep you posted on this
Old 22-08-2008   #14
Autotest Special
rallycinq's Avatar
Trader Rating: 1
I am afraid I don't know where they are on the MPi cars, sorry.
PD
Old 24-08-2008   #15
OK got myself an RAC fault code reader from argos today part number 740/2742 - AMAZING piece of kit you have to get one - told me that P0352 fault - Ignition coil B Circuit Malfunction. Getting closer to the fault. anyway know what this might be - it has had 2 new coils, leads plugs, compression test was brilliant, fuses checked etc - any wierd faults it could be???
(T) SEICENTO firing only on 1 + 4 URGENT HELP waftylofty Cinquecento / Seicento 10 24-09-2007 22:18
(G) Intermittent firing. vinman Ducato 2 27-05-2007 19:56
(T) Marea not firing on 1st cylinder scubarooney Marea 7 23-03-2007 12:32
(T) Spark Plugs/Cylinder Mis-firing jnorms Cinquecento / Seicento 15 08-07-2005 11:04
