Thread Tools
Old 24-08-2008   #16
Trader Rating: 5
fingers99 has donated!
Re: seicento not firing on 2 and 3 cylinder
It's a wiring fault in the coil circuit. Pull the insulation off, check it visually.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 24-08-2008   #17
Trader Rating: 3
ycming has donated!
hold on a mintue ... is the sei OBD1/OBD2 ????
I thought it uses the same ecu as the cinq ?
Ming
Wanted : Nothing at the moment
ycming is offline Reply With Quote Quote
Old 24-08-2008   #18
Trader Rating: 5
Quote Originally Posted by ycming View Post
Ming
MPI Seis are OBD2.
Cinqs are OB1Kinobe.
M12 fund 20
Old 24-08-2008   #19
Bring On The Trumpets!
ronnieronson's Avatar
ronnieronson has donated!
Quote Originally Posted by nokiaman2002 View Post
OK got myself an RAC fault code reader from argos today part number 740/2742 - AMAZING piece of kit you have to get one - told me that P0352 fault - Ignition coil B Circuit Malfunction. Getting closer to the fault. anyway know what this might be - it has had 2 new coils, leads plugs, compression test was brilliant, fuses checked etc - any wierd faults it could be???
just because there's a problem being flagged with that number - doesn't mean that it's the coil.
Try greasing the contacts with vaseline - if that doesn't work I'd say you need to take back the wiring from that coil all the way to the ecu end of the loom and replace it.
ronnieronson is offline Reply With Quote Quote
Old 24-08-2008   #20
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
OOO, an amazing piece of kit that tells you pretty much what you were told on here.
Hope its worth the money.
Pah
PD
Old 25-08-2008   #21
always handy to have tho - reading around this fault is quite common - the cause can be a faulty coil pack or arcing plug lead - the voltage goes to earth and blows the ECU, apparantly the problem is quite common - just wish i had a diagram showing the ECU pinouts! I have checked the connections and they are all fine - i have attached 2 pics of the ecu - if anyone has this ECU "lying about" with the immobiliser box aswell I would be very interested. Or if somebody knows what pin goes where i can do more fault tracing but without a pin diagram I can only guess.
ID:	49128   Click image for larger version
nokiaman2002 is offline Reply With Quote Quote
Old 25-08-2008   #22
Banned
Oldschool has donated!
You need to replace the ECU. Unfortunataly the HW number is wiped out on your ECU, but since it is a 2001 MPI it most likely has got a HW below 103, which was a problem ECU. The processor corrupts the program and most common fault was not firing coil number 2 (cylinder 2 and 3).
Oldschool is offline Reply With Quote Quote
Old 25-08-2008   #23
yeah i thought it was gonna be that - attached is another pic that might help if anyone has one
Name:	MPI_ECU_1108cc seicento.JPG
Old 25-08-2008   #24
so presumably the HW number is the HW024?
If so I'm starting to think ECU faults may be what has been causing my weird running....
Should be interesting to see how this turns out.
In fairness if you need a new ecu, there's a place on ebay who do recon units (on the basis that you send yours back to them) - and fairly cheaply at around 100, plug and play, no need for messing with code boxes/keys/etc...
Old 25-08-2008   #25
Yeah i rang that guy his name is ricky - very helpful guy and he knows his ecus- he doesnt have one for mine - mine is a different ECU! typical - just ringing round scrap yards now - i have created a new thread for my ecu but will hopefully get it sorted soon
Old 29-09-2008   #26
Hi nokiaman2002
Did you get the problem sorted as I seem to have a very similar problem with the engine warning light and it not firing on all cylinders. Can you give me that guys number or email address for the ECUs.
Regards Nick
nicknoo is offline Reply With Quote Quote
Thread Tools
(T) SEICENTO firing only on 1 + 4 URGENT HELP waftylofty Cinquecento / Seicento 10 24-09-2007 23:18
(G) Intermittent firing. vinman Ducato 2 27-05-2007 20:56
(T) Marea not firing on 1st cylinder scubarooney Marea 7 23-03-2007 13:32
(T) Spark Plugs/Cylinder Mis-firing jnorms Cinquecento / Seicento 15 08-07-2005 12:04
