been hitting a few oil drums while using the handbrake due to the ratchet. so today I stripped and worked out how to make work the oposite to the standard handbrake. looks ugly but works brilliantly!
not to botherd really. I have rear discs and will only use it about 10times at an event so not really going to stretch the cable enough to notice.nice,shame its not hydraulic tho
I know about that but I also plan on doing sprints. Im going to get a set of new pads for the rear then do some work to get more leverage. at the min I can only pull it up 3 clicks before its solid... hummmRear drums are great for autotesting
auto testing. going around a course laid out with cones as quick as you can without hitting any cones or taking the wrong test... which is pretty hard at speed on the complicated ones.hmm care to explain the reason doing that ???
not meaning to sound like a party pooper, but is that street legal?
Is it possible to run both. hydraulic for sprints and tests, then mech for MOT purposes? would be a pain to do i expect.
