Technical Seicento gearbox queries
Crawley
Hello there!
I am currently looking at buying a seicento to save from the crusher (being as a car will now fetch £100 - £150), though I need some info.
The gearbox in this one is constanty jammed in what seems to be the same gear where ever you put the gear sick and the stick moves correctly but a little stiff.
Sounds like its knackered to me, though how badlly?
Also how do you take it out? from my brief look it might be dropped out of the bottom?
Any help very greatfully received.
Jon
Check that things move under the bonnet when the gearlever is moved. It sounds like a cable has popped off, or one of the outer cables is not secured on the gearbox properly.
Gear lever comes out from the bottom, not that difficult to do.
Pd
