Is there a safety cut out on the 1.1 Sporting?
My wifes Seicento keeps on losing all power at 3.2 rpm and then regains power when you change gear.
It then cuts out again at the same point and you need to change gear again to keep the car going.
After fifth gear there's no where else to go than to start changing down.
I've been told that it's the safety cut out working because the car has a major engine problem. Is that right? The advice was to change the MAP sensor so I did but it makes no difference.
