not too interested about fuel economy etc, but will other ecu's (uncoded obviously) for example 899 cinq ecu's get the car to start / run?
Eh?
What have you done/what are you trying to do? Which car?
I don't think an 889 ECU would give enough fuel to do anything usefull (and the pinout could wll be wrong).
See if you can get hold of an MPI ECU with a key. Untested, this, but should work.
Swap the ECUs over, hang the new key near the inductor, and you should be able to start using your old key.
If it cures it, try and get Timsons to make you a key with the new key's code, cut to the old pattern.
But lumpy idle could be little more than a valve issue. Compression test? Check the clearances.
I have an mpi ecu ... what version do you have? 4af? one or two plugs?
Kristian
an 899cc cinq ECU won't even fit nevermind run the engine..
Jesus christ not again!
i bet you havent done the compression test yet have you? Is there any reason why you are avoiding doing this?
wouldnt expect no4 to be oily, only no1 as its near the oil cap. unless its just seeping down the from a leaky cam cover gasket.
BUT i would class a variance of 1bar between two cylinders (ie what you have) as indicitive of a problem.
blow down test?Can't really conclude a lot from those figures. Don't seem far out. No.4 may have a knackered valve guide which a blow down test might show up. Worthwhile checking the valve clearances, though: chances are it has never been done since the engine left Poland!
I'd not expect it to be oily 'cos that cylinder runs a bit hotter. But are we talking oily outside, or oily on the inside? And where inside?
It's, what, 7.5% or so? (Can't do the maths, have touch of arc eye, need sleep.) Anything more than 5% spells trouble on a competition engine, but on a road car with who knows what mileage? More significant may be that 2 adjoining cylinders show lower figures.
Ronnie, I think you're trying to fix a car that's working perfectly.
has nothing to do with it. you could cut the accelerator cable and the car should idle perfectly. it has handled by the idle control valve, not the throttle butterfly.
