my engine is now in bits, just need to arrange to get the head skimmed. ive bought a head gasket set from fiat, but i havent opened it.. i dont wanna start doing that till i need it so it doesnt get crap on it. when you take the coil packs off, there is a rubber o ring on the end of the cam. Does that need replacing everytime, and do i get one with the gasket set.
Also, the timing is going to need setting up again. Could someone give me a run down on how to do this. I would just set the engine to tdc and then wedge the flywheel, but i think the timing is out by a tooth anyway so when the new belt goes on i want to make sure its right.
thanks peoples
thanks peoples
