General Rear drum problem
Newport
Hi, I've had a search and I think I know the problem.
When I first got the car I noticed that it had problems pulling off as if the handbrake was stuck on. I have a feeling somewhere the rear brakes are seized as it needs a bit of hardcore revving to push it past the bite so it wont stall.
Anyone know where exactly the problem might be, I heard before that sometimes the rear actuators? or something seize partially.
I don't know, I'm just guessing, but it this a hard job to sort out? How long would it take a garage normally?
Cheers, Luke.
It also has the problem when you clutch control, the car will dip, I mean a lot more than average.
Cheers fingers, will take it on a run in a bit and post results.
Luke.
Mine had this problem ,and I found it was the handbrake cable that had seized. Also if the actuaters are seized its not a big job to do, but its better to change them rather than trying to free them up.
If you find its the cable. Make sure you get a Proper Fiat one if you replace it. I wasted a lot of time with a crappy one from a 'Italian car/fiat specialist' which was about 2 inches too long! The fiat part was cheaper too about £20 with postage from ebay!
Probably got the wrong one: if the car is a Cinq with Sei stalks (as fitted by the factory!) get a Sei one, otherwise a Cinq one.
It's always a good (but messy!) idea to lubricate the cables (I like motorcycle chain spray) before fitting. Just poke the straw thing in past the rubbers on the outer and blast away. (Don't do it in the house!);)
Thanks guys, I'll have to take it down the garage and see what they say. I'm not sure about the cable, I live on a massive hill and the handbrake has to be up to it's max to keep me there. It'll stay but I prefer to keep it in gear :/
Luke.
Luke.
Start buying tools instead of paying the garage, then you can begin to work on your own car.
PD
Don't replace the cylinders unless they're seized/leaking: they have bugger all effect on the handbrake, anyway!
The only hard(ish) bit is replacing/removing the springs a tool like this
will cost you less than a tenner from your friendly local factor.
Do one side at a time, replace the shoes if they have less than 1.5mm of material left. Otherwise, very straightforward.
