im Axle Specialists
Old 25-05-2008   #1
bigS has donated!
Ireland
Pistons?
i was wondering if the pistons are mean't to hit the valves on the cylinder head? because i'm in the middle of changing my head gasket and noticed ring imprints on the top of my pistons? want to know before i go buying the wrong stuff for a different problem.
Shannon
bigS is offline Reply With Quote Quote
Old 25-05-2008   #2
Trader Rating: 5
fingers99 has donated!
Re: Pistons?
1108 (at least) has small cut outs for the valves. But, tell us more. What engine, what problems, pics?
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 25-05-2008   #3
bigS has donated!
Ireland
Re: Pistons?
Yea it's an 1108, must just be the cut outs. i'll go take some pics now. Also if there is a lack of compression is it always the head gasket? because i took the whole engine down and there was no HG fail but there was serious lack of compression. could it be the spark plugs?
Shannon
Old 25-05-2008   #4
Trader Rating: 5
Re: Pistons?
Could be valves. Unlikely to be spark plugs unless the thread is completely shot. For future reference, always get a compression test done before pulling a head. Anyway, makes sense to skim the head, get the seats re cut, new valve guide oil seals, re-shim the valves.
If the compresssion is low after that, it can only be the rings/pistons.
M12 fund 20
Old 25-05-2008   #5
bigS has donated!
Ireland
Re: Pistons?
I did the compression test before hand, thats why i thought it was the HG but it doesn't seem to bad. i'm trying to get the head skimmed sometime this week all going well.
Shannon
Old 25-05-2008   #6
bigS has donated!
Ireland
Re: Pistons?
Old 25-05-2008   #7
Trader Rating: 5
Re: Pistons?
If there's been contact, you'll always see a bright ring. Can't tell a lot from the head (except no rot) and gasket.
Generally if the HG has gone you'll see low comp on one cylinder or two adjoining ones.
M12 fund 20
Old 25-05-2008   #8
kritip's Avatar
Trader Rating: 4
kritip has donated!
Re: Pistons?
What actually were the results on all of the cylinders then?
Did you run the test with all the plugs out, throttle open, and a warm engine?
I had low compression on all my cylinder. For me the lands were broken on the pistons. Thought thats not very common, it could be the rings.
How many miles has the engine done?
Kristian
kritip is offline Reply With Quote Quote
Old 25-05-2008   #9
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: Pistons?
There are no witness marks on the valves to suggest contact with the pistons.
How are the bores?
On the engine we stripped to become my race engine, the bores were barrel shaped. Quite tight at TDC on each piston but very wobbly when in the middle of its travel, and this was an engine with no known overheating problems.
Gormless Cretin
Old 25-05-2008   #10
bigS has donated!
Ireland
Re: Pistons?
the throttle wasn't open but the engine was well warmed and all the plugs were out. the results i got were very different:
140 psi
105 psi
124 psi
115 psi
but i found recently that the timing was off on the car. Who ever owned the car before me fitted a timing belt and the timings was off as i found today when inspecting it. When taking the head off, i only lined up the crankshaft pully toi TDC but when i checked earlier the camshaft pulley wasn't on TDC when the crankshaft was. so maybe this could be to do with off timing? i'm not sure
the bores are fine. doesn't seem to be any scrape or scratches for the pistons.
Shannon
Old 26-05-2008   #11
Trader Rating: 5
Re: Pistons?
Timing shouldn't affect the compression readings. Difficult call now it's in bits.
I think (depending on how broke I was/how much time I had) I'd go through the head carefully, the usual stick everything from one cylinder in one freezer bag rountine, check for guide/valve wear, etc. and then skim, cut in valves, re-shim. That way at least you know you have a good head.
Unless it has done say 80k miles plus, in which case it's unlikely not to need a rebore.
M12 fund 20
Old 26-05-2008   #12
kritip's Avatar
Trader Rating: 4
kritip has donated!
Re: Pistons?
If the timing is a bit out, could it not leave the inlet or exhaust valves open longer on the compression stoke, giving a low reading? Of course, if it was this far out, it would have run like a bag of nails as well.
Kristian
Old 26-05-2008   #13
Trader Rating: 5
Re: Pistons?
Maybe (that's a new experiment for you, Kris!), but you'd still expect them to be out the same amount, wouldn't you?
M12 fund 20
Old 26-05-2008   #14
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Re: Pistons?
It would have been handy to see the results of a wet versus dry test, but I think that one and three are close enough, its two and four where the problems lie.
Gormless Cretin
which pistons? mick.p Lets Talk FIAT 1 09-11-2007 19:56
Forged pistons. richcinq Lets Talk FIAT 4 25-05-2006 01:54
(T) where can i get some performance pistons from? lwnicklin Punto (Mk2/2b) 1 03-04-2006 14:23
(T) pistons!! dazzdog Coupe 4 04-07-2005 18:50
(T) Pistons Frequency Hz Punto (Mk1) 0 31-07-2003 03:27
