Well I'd like to say the 16v in the Imola Cinq was mine but it's all the great handy work of Andy Duff from the Cinqs&Seis list.
The 16v on throtle bodies is another load of handy (assisted) work also from a guy called Andy (Ellsom this time)
1st one is a journey into the unknown as the second has non Fiat management and would appear easier.
Mr Duff is likely to have started a new job so doubt if the 16v has moved much but last I heard he was having the engine out again to re-check the loom over 1 final time before completion, sounds sooky but he's a brainy bugger when it comes to this stuff so he's a possible source of help for you Tom, not that the help here isn't enough though.
Liam
'97 Cinq Sporting, Imola Blue, Bumpers inserts and some parts painted red to colur code with seat belts,K&N, Janspeed S1 System, Tarox X drilled n grooved disc, SPAX ADJ. Dampers, Eibach Springs, Eibach Anti roll bar kit, OMP lower strut brace and some ICE
