FIAT Auto Specialist Team
Old 27-07-2004   #1
mckcrich has donated!
Cinq Sporting Performance Chip
At long last - the Cinquecento Sporting performance chip is now ready. The chip is available for the Weber/Mareli IAW-16F-ER ECU
Extensive testing in 3 different Cinqs reveal the following features and benefits*:
• Increases torque and power across the whole rev range by an average of about 6%.
• Maximum increase in power of approx. 9% @ 3,000 RPM
• Maximum increase in torque of approx. 8.8% @ 4,500 RPM
• Increases Maximum Power by approx. 3.5%
• Increases Maximum Torque by approx. 6.8%
• Reduces 0-60 time by average of about 1 second [ from 60.05 in 13.3s to 60.125 in 12.4s]
• I think that it slightly decreases fuel consumption - on average my mpg increased from just over 40 to just over 43 over a month on a mix of cross country and fast motorway driving, but to be honest this could be spurious.
• Disables immobiliser circuit; This allows you to fit the chip in any ECU so you can have a separate ECU for track days for example. (Although if you are using it permanently you may want to fit an alternative immobiliser)
(Interestingly this solves the problem of losing the Red Key as any key that fits the steering lock will start the car)
To be entirely honest this chip is not as good as the claimed performance for Superchip™or Starchip™ but then it’s not priced at over 250
*[Test data from 1997 Cinq sporting, standard (apart from Ramair panel filter) 4 runs, 2 in each direction at 10C 1026mb and 78RH. – measured using a Dyno Plus accelerometer and RACE evaluation software. (probably not as accurate as a rolling road but nevertheless a very good indication as a comparison) N.B. Performance improvements will vary dependent on many variables not least the car and the weather for example on a low pressure wet day the improvement seen was only about half that gained on a dry high pressure cool evening]
Click here to see the Performance Graphs http://www.crich.plus.com/index.html
I'm really happy with the cars performance with the chip It makes the car more drivable, particularly at lower revs where it pulls much stronger (due to the greater torque I presume), it gets rid of the flat spot and improves acceleration considerably. I've recently added further mods to my car [A BMC type induction kit and a Magnex backbox] The chip works great with these mods and still improves the performance further. There was a noticeable difference when I took it out for a while.
The chip is made available for 80, but I must stress that I am not selling the chip you will be joining the development project to further test the programme [all that will be required is a testimonal statement that I can publish].
I'm happy to run before and after performance comparisons with graphs for an additional 40 with no charge if the chip does not increase performance.
I have put a lot of time and effort and a fair bit of money into the project together with a friend who normally charges 800 per day for electronic design work. I have tested it in my own car for three months and it has been fine. It has also been tested for shorter periods of time in two other cinq sportings with absolutely no problems.
The chip is easy to fit providing your existing chip is socketed and not soldered to the ECU board. (I think this is only an issue for late 97 and 98 cars). It takes about 30 minutes to an hour and full fitting instructions will be provided
I must stress that it is important that you make sure that you inform your insurance company and that they will cover you for the Chip Modification.
Anyone who uses the chip does so completely at their own risk I am not a big corporation I cannot guarantee it will not destroy your engine (although I think this is highly unlikely). There is a degree of risk in joining the project, and I need to be sure that everyone is aware of the risk.
What I will do is refund in full anyone who returns the chip within 14 days if they are not happy with it or with being part of the project for any reason.
If you want to use the chip and join the programme send a cheque for 80 to:
Michael Crich
145a Leicester Road
Broughton Astley
Leicestershire
LE9 6QF
or pay by credit card through Nochex by sending 82.30 (includes their fees) to mick@crich.plus.com (go to www.nochex.com )
Any questions or further information PM me here or email to chip@crich.plus.com
Regards,
Michael
times change and so do prices ;) chip price is now around 42.put this here so people see it 1st.PM mckcrich for info/orders
mckcrich is offline Reply With Quote Quote
Old 27-07-2004   #2
Winning
GhostWKD's Avatar
GhostWKD has donated!
aragh this would come just as ive got lots of cash to spend to get my car through the mot :(
will you still have these around in a few months? :(
Abarth Kitted Cinq Sporting, Sig coming soon ;)
GhostWKD is offline Reply With Quote Quote
Old 27-07-2004   #3
Chip will be available as from now for as long as people want them.
Regards,
Michael
Old 28-07-2004   #4
hi friends :waves:
Liam's Avatar
Liam has donated!
Been waiting for this to come to fruition for a while, slightly sceptical but will wait to see what other owners comments are before taking up any offers.
Good work, hope it goes well for you.
Liam
'97 Cinq Sporting, Imola Blue, Bumpers inserts and some parts painted red to colur code with seat belts,K&N, Janspeed S1 System, Tarox X drilled n grooved disc, SPAX ADJ. Dampers, Eibach Springs, Eibach Anti roll bar kit, OMP lower strut brace and some ICE
Liam is offline Reply With Quote Quote
Old 28-07-2004   #5
Liam,
If your going to be down my way at any time come and try it out with no obligation.
Regards,
Michael
Old 28-07-2004   #6
hi friends :waves:
Liam's Avatar
Liam has donated!
301 miles...........some said my Durham trip was madness but I'm unperturbed by the distance so it maybe a possibility.
Thanks for the kind offer.
Liam
Old 29-07-2004   #7
is the ecu the same on the cinq as the sei?
i love novas but its time for a change
fordy is offline Reply With Quote Quote
Old 29-07-2004   #8
The ECU on a 1108 sie sporting should be the same you can easily check as it should IAW 16F ER on the stick on top of the ECU.
I hope this helps
'97 Cinq Sporting, Imola Blue, lowered with a few performance mods and a Minidisk/CD system
Old 30-07-2004   #9
Winning
GhostWKD's Avatar
its the same on the spi sei's i think
Old 20-10-2004   #10
Re: Cinq Sporting Performance Chip
Got one that will work in the 1242 8v engine?
If so I'm intrested...
Regards,
Matt
I like the idea of:
Full Zorst system
GSR BMC CDA Induction kit
1.2 8v
Gas Flowed Head
Lightened and Balenced Flywheel
6 Speed 'Box
... and eventually the Red'un should be pretty nippy ...
Gone To UNI Not around that much anymore....
http://www.clubfirepower.co.uk/forum/index.php - Visit this Site!!
bad_boy_racer is offline Reply With Quote Quote
Old 21-10-2004   #11
Quote Originally Posted by bad_boy_racer
Regards,
Matt
I like the idea of:
Full Zorst system
1.2 8v
Gas Flowed Head
6 Speed 'Box
IIRC - From a post that Pete (fix it again tomorrow) put up I reckon it will work with the 1242, providing you are still running the original ECU. Pete Runs his 1242 with a 1108 superchip. Anyhow You are welcome to try it out if you are not happy I will refund the price on return.
Michael
Michael,
Developer of the mckcrich chip - more power per than any other mod you can buy for your cento (or punto)
Old 21-10-2004   #12
ive jus bought this off ebay wot u think
http://64.4.53.250/cgi-bin/linkrd?_l...m%3d7928981380
blondblackbrunette is offline Reply With Quote Quote
Old 21-10-2004   #13
Cento Boy
surfin_fella's Avatar
surfin_fella has donated!
Quote Originally Posted by blondblackbrunette
That was the biggest waste of your money ever. As soon as you get it, burn it. Wanna know why? Search the forum for the answer
Sie - Proud advocate of Centoism
Cinquecento60
Clubcento - The UK Cinquecento and Seicento Owners Club Clubcento Forum
surfin_fella is offline Reply With Quote Quote
Old 21-10-2004   #14
how much these chips u got jus paid tenner for mine
Old 22-10-2004   #15
The chip is nothing like the resistor mods on ebay which is a 10p resistor and does not work.
My chip is a complete engine remap and is now reduced to 40 with full fitting instructions and moneyback guarentee.
Michael
Michael,
(G) Performance Chip Development mckcrich Cinquecento / Seicento 13 27-04-2004 05:15
(T) suspention on cinq sporting mackett Cinquecento / Seicento 6 04-12-2003 22:45
