Old 13-05-2008   #1
kritip's Avatar
Trader Rating: 4
kritip has donated!
1368cc pictures (internals) - Engine problem diagnosis
Following on from my oil consumption thread, I decided to strip the engine, took loads of pics, so thought they may be of interest!
Started stripping to find oil in the throttle body, removed the injectors to find oil on them, removed manifold to find the closed valves were actually hidden by little puddles of oil on top of them!!!!!!!!
ID:	43415 Click image for larger version
ID:	43416 Click image for larger version
Here is the block after the head removal. The coolant leaked in on removal.....not sure about all the oil in there though :S
Here is the bore...note the honing marks and also some wear marks:
Here is the top of the head....at least all the valves are still there, and don't appear bent:
Here is the underside of the head:
Here are some more marks on the bore:
Looks like the pistons will have to come out now
There doesn't appear to be anything majorly wrong at the top, but signs point to some possible piston problems. Never stripped a bottom end before, so not sure how easy/messy it is, and what to expect.
I do have a Haynes manual though, for a 1242 16v, which should help me out a bit.
If it is a piston problem though, how does that explain the oil in the inlet?
One other thing to note.....once the cams a locked the pistons should be 4 in line, but two were at 47.5mm from deck height, the other two were 51mm, so the belt wasn't 100% timed up!!!
What this difference makes in terms of degrees, I'm unsure of, it may be negligible.
If it need piston work or re-boring etc....it means the whole lot has to come out
Hope you enjoyed the pics anyway
Kristian
kritip is offline Reply With Quote Quote
Old 13-05-2008   #2
Trader Rating: 5
fingers99 has donated!
Re: 1368cc pictures (internals) - Engine problem diagnosis
I'd guess the oil is blow by.
Oh poo.
Pics of the bottom end would be cool.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 13-05-2008   #3
kritip's Avatar
Trader Rating: 4
kritip has donated!
I think so too!
I will ring one of a few local rebuilders tomorrow...they may confirm and prefer the block with pistons in. If i pull it though...trust me, there will be pictures
Kristian
Old 13-05-2008   #4
Trader Rating: 1
cc1 has donated!
Sounds like crank case pressure build up and blowing oil through the crank case breather into the throttle body.
cc1 is offline Reply With Quote Quote
Old 13-05-2008   #5
kritip's Avatar
Trader Rating: 4
kritip has donated!
Yeah, but LOTS of oil, and that will be caused by the rings gone won't it.
Hey chris, your 1242 sitting about and in good nick
Pretty annoyed about it to be honest. I guess it could be esy to balme self mapping and the megasquirt, but i never had any issues on the 1242 16v and made a lot more miles on that!
It did it from day one, the funny noise...i just though it was a water pump bearing rattle or similar....it was probably the pistons slapping about at high rpm!
Kristian
Old 14-05-2008   #6
meh bad luck fella, gl with rebuild am sure you wouldnt have a problem doing it yourself tbh :P
Van Aaken High Boost Turbo Cinq In Caribean Orange, Highly Modded
Whiley is offline Reply With Quote Quote
Old 14-05-2008   #7
Trader Rating: 1
cc1 has donated!
Only with a full strip and measuring equipment can you tell if things are ok.
With that amount of oil in the intake, It has to be coming from the head vent pipe.
Old 14-05-2008   #8
Has sport button disease
100hpJames's Avatar
100hpJames has donated!
switch the engine with your mums and get hers repaired under warranty...... *wakes up* lol
Abarth GP, leather, climate, stripe, no mods yet
100hpJames is offline Reply With Quote Quote
Old 14-05-2008   #9
Trader Rating: 1
cc1 has donated!
Don't realy trust engines from scrappies as you don't know where they have been stored and for how long.
If the car was a rear ender, then maybe the driver couldn't and had abused the thing from day one? Strange things happen, Like the poeple on a plane traveling back from a flight safety conference and it crashed....
Old 14-05-2008   #10
Trader Rating: 1
cc1 has donated!
If you feel you need my 1242 to keep you going whilst the 1368 is under investigation then your welcome to it as I have no plans for it as yet. Sweet engine.
Old 14-05-2008   #11
kritip's Avatar
Trader Rating: 4
kritip has donated!
Quote Originally Posted by Whiley View Post
I will strip it and put it back, but if it needs honing and rings, i've never doen it before, can't afford for it to go wrong, and not 100% on waht to do. As gasket sets are 50+, one restrip and your a whole lot of money less.
Quote Originally Posted by cc1 View Post
Yep, I'll chat to some local rebuilders....what they want, they get, block, pistons, etc. Its a bit of an art, and not as simple as most stuff i do...plus most of them talk in funny language...thous, 0.00's of an inch etc :S :P
Quote Originally Posted by 100hpJames View Post
I did consider, but i don't fancy castration
James suggested timing belt slipped on impact....possible from what i've meausered.
The engine are a bit thirsty regrdless, I know my mums 100hp needed several top ups and is only at 9K itself. Perhaps it never had a top up or attention before the crash...or maybe it locked up causing a crash
My last engine, 1242 16v was from scrappy, dragged off the muddy floor, no history, but i stipped the top, rebuilt and it was mint! I think i was complacent with this as it was low miles. Any unkonwn engine in the future will get a complete strip down It doesn't make sense not too in the long run.
Cheers,
Kristian
Old 14-05-2008   #12
kritip's Avatar
Trader Rating: 4
kritip has donated!
your a very decent guy!
It was only said in jest, but if it comes to the 21st and its not runnig, you may get a call
Shame you haven't made use if it yet..it's a real blast!
Kristian
Old 14-05-2008   #13
arc
this is where i stand
arc has donated!
fook, i see what you mean about the oil
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 14-05-2008   #14
Trader Rating: 1
Quote Originally Posted by kritip View Post
A thou of an inch is 0.001"
Brooky is offline Reply With Quote Quote
Old 14-05-2008   #15
kritip's Avatar
Trader Rating: 4
kritip has donated!
Quote Originally Posted by arc View Post
yep, at least its only done 300 miles and is niec and clean thats the only savin grace.
Kristian
(T) Pictures of the engine bay or starter motor. jammydodger87 Cinquecento / Seicento 0 11-01-2008 19:11
(T) electirc wing mirror internals smtvlive Marea 3 20-05-2006 10:27
(T) 6 speed internals fordy Cinquecento / Seicento 24 18-07-2004 00:25
