Just a couple of questions on ECUs
I hear there are coded version (16F) and a non coded version from earlier models (6F) would it be possible to swap a coded ECU for a non coded one?
Is it possible to swap two coded ECUs over then swap the code box under the ignition barrel. Then remove the code chips from the donor ECUs keys and place them in the old keys as to save changing the ignition barrels and locks etc?
Is it possible to swap coded two ECUs then swap the code chips over (as one would insert a mckritch chip) to save swapping anything else?
