Thread Tools
Old 04-05-2008   #1
Bring On The Trumpets!
ronnieronson's Avatar
ronnieronson has donated!
Quick clutch cable adjustment question
So - if I turn the nut clockwise (as I face the windscreen) that is going to raise the clutch pedal yes? and anti clockwise will drop the clutch pedal height yes?
If the above is true (?) then which do I need to do to soften the bite so that the clutch holds a little when I take my foot off the pedal if that makes sense?
Just took a drive in the wifes clio, and her clutch pedal is quite soft, in the sense that you can let up quite quickly on the pedal, but the gear change is nice and smooth.
My old cinq was like this also - but I think something's wrong with the way I've adjusted the Sei as its rather jerky on downchanges (which may or may not be associated with another problem I'm in the middle of sorting)...
Anyway - any input would be much appreciated
ronnieronson is offline Reply With Quote Quote
Old 05-05-2008   #2
Re: Quick clutch cable adjustment question
anyone?
Old 05-05-2008   #3
Trader Rating: 5
fingers99 has donated!
Travel (or difference between up and down measured from the steering wheel with a tape measure) should be between 115 and 155mm (it says here).
All else being OK, turning clockwise will lower the point of engagement.
I guess the Clio has a hydraulic clutch, so it'll adjust itself (until it dies).
Thanks ronnieronson thanked for this post
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 05-05-2008   #4
Quote Originally Posted by fingers99 View Post
ah.... that sorta makes sense then.
I think my car will be getting treated to a new clutch at some point - although I'm not 100% certain it needs it (yet - will have to see what happens when I've got the calipers re-adjusted).
Will have a fiddle with the adjustment and see if I can make things a little softer
Thread Tools
(T) Quick clutch cable question... bassy-alex Cinquecento / Seicento 1 05-08-2007 14:55
(G) 1st gear difficult to select. Clutch cable adjustment needed? Andersh Cinquecento / Seicento 5 23-04-2007 23:58
(T) Clutch cable adjustment BARMIKE Bravo / Brava 12 26-03-2007 16:57
(T) HELP QUICK, Clutch Cable warrior Cinquecento / Seicento 6 09-05-2006 18:59
(T) Clutch cable adjustment. nicholas Cinquecento / Seicento 8 12-02-2003 22:58
