General Heating Issue Seicento S 1.1
jjbrien
Dublin
Ok a funny thing happend today when i was driving home from work the heating started to have itermittant problems it could come on for 30 seconds and then you get a blast of cold air. Its very stange also i notice the sterio is not light up the same way it used to its not bright anymore? I am wondering does anybody know what to do ?
Is it the battery I put a new battery in it in Jan 07 is this on the way out or is this something else?
Something else.
Check the coolant level and if it needs topped up, remember to bleed it.
The radio problem can't really be connected, I don't think, but check the alternator output while you're under the bonnet.
D
Something else.
D
How do you bleed it?
its the internal heat not he engine
The internal heat gets its heat from the engine. Its the cooling water from the engine that gets circulated through the heater matrix for you to get heat in the car.
There is a bleed screw behind the offside headlamp, assuming RHD, and maybe one on the bulkhead where the pipe comes out of the matrix.
D
D
ok will look tomrrow.
