Old 30-04-2008   #1
MOT failure, brake binding and headlights too high?
Ok so I had my MOT yesterday, and it failed on a few things. The most confusing to me is that the front headlight beams are too high. I understand that in some cars you have a switch inside that adjusts this, but I dont so how have they gotten too high, and how is that fixed??
Secondly was that the front drivers side brake is binding, I didnt really understand what this meant, so nayone explanations and possiblilities why would be great.
Also it failed on parking brake, as it was lower than required, I had it tightened about 6 minths ago and the guy did say something about it, although what he said I cant remember as my partner picked the car up, I think it was about the pads being worn or something, are these simple to change?
Just wondering how much it's going to set my back as the MOT man was useless and foreign and no idea what he was saying.
Thank you.
jammydodger87 is offline Reply With Quote Quote
Old 30-04-2008   #2
Trader Rating: 5
fingers99 has donated!
Re: MOT failure, brake binding and headlights too high?
What does the failure sheet say?
The headlamp aim too high can really only be adjusted by a garage with the right equipment: not a huge job.
Binding brake is usually down to a piston or arm sticking in the caliper itself. Not a huge or difficult job, but you need to know what you're doing. You might try getting a caliper from a scrappy and changing the pads (both sides).
As for the handbrake, there's a lot of stuff in the FAQ (or guides -- can't remember which).
M12 fund £20
fingers99 is offline Reply With Quote Quote
Old 30-04-2008   #3
Ok, that's good then, I thought the headlights would just stay the same height (Shows how little I know).
My friend will hopefully know how to do the brakes.
Just want it to be as cheap as possible (as everyone does I'm sure), their was an advisory note about the front brake hoses being deterioated, I dont know if that could affect the brake binding?
Old 30-04-2008   #4
Trader Rating: 5
It has been known. They're cheap, so I'd give it a go.
M12 fund £20
Old 30-04-2008   #5
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Its very possible that the brake hose is the fault. If it needs changing, then do that first and see whether the binding stops.
D
(G) Brake Pressure Regulator: MOT Failure chr1s Ulysse 14 16-08-2009 21:31
(G) brake binding help Nick7214 Cinquecento / Seicento 6 27-09-2007 21:33
(T) brake binding mugatea Cinquecento / Seicento 11 23-09-2005 14:25
(T) High lambda mot failure fishdude Bravo / Brava 11 03-09-2005 15:36
(T) High lambda mot failure fishdude Bravo / Brava 0 02-09-2005 21:47
