fatty
HELLLLP!!! I'm currently taking the 32mm TB off the Punto. I've read the guide in the cinquecento guides section and it says if you split the TB you won't have to remove the coolant/fuel pipes. However there still appears to be pipes both coolant and fuel attached to the bottom of the TB!! ARGGGGH! Help!! Are these gunna spew fuel and coolant?? Is this different to the Cinq??
