| Thread Tools |
![]() | #1 |
Posts: 309 Thanks: 1 Trader Rating: 0 ![]() | which way are in/out oil fittings on the garrett T15 turbo? hi people. im near to fitting this turbo to my manifold but if spun it all round so much i cant work out with is the oil in side. and which is the oil drain side. one side has a threaded fitting for a plumbing style pipe the other has a flat area with 2 bolt holes for a gasket and ovel plate to the bolted on. which is in? which is out/drain? much appreciated. thanks aran.
__________________ Current owner of a ----------Creator of a beasty 40mm lower COLOUR---------- 1242cc white 4x4 ![]() |
![]() | #2 |
![]() | Re: which way are in/out oil fittings on the garrett T15 turbo? The threaded one is the "in" side (must be on top) and t'other the drain.
__________________ M12 fund £20 |
![]() | #3 |
Posts: 309 Thanks: 1 Trader Rating: 0 ![]() | Re: which way are in/out oil fittings on the garrett T15 turbo?
![]() | #4 |
this is where i stand Join Date: Oct 2003 Location: Manchester
Posts: 13,581 Thanks: 289 Trader Rating: 0 ![]() | Re: which way are in/out oil fittings on the garrett T15 turbo? needs to drain off at about 10deg off vertical as well.
__________________ .:: 1368cc 16v Cinquecento ::. |
Thread Tools | |
Garrett T15 compact turbocharger | CaneyJ | Auction Watch | 12 | 28-10-2008 15:35 |
![]() | fordcosworth | Cinquecento / Seicento | 27 | 21-03-2008 00:55 |
Garrett T15 Turbo, Cheap as Chips | CaneyJ | Auction Watch | 1 | 22-06-2006 00:55 |
![]() | J333EVO | Cinquecento / Seicento | 28 | 08-11-2005 00:55 |
