General which way are in/out oil fittings on the garrett T15 turbo?
Xsisley
Member
Hebden Bridge
hi people.
im near to fitting this turbo to my manifold
but if spun it all round so much i cant work out with is the oil in side. and which is the oil drain side.
one side has a threaded fitting for a plumbing style pipe
the other has a flat area with 2 bolt holes for a gasket and ovel plate to the bolted on.
which is in? which is out/drain?
much appreciated.
thanks
aran.
