Thread Tools
Old 02-03-2008   #1
Punto 75 mpi conversion
It's time I put a bit more poke into the Sei, after reading the following in the FAQ's ive more or less decided this will be the easiest, cheapest and best bang for buck conversion for me.
Quote Quote:
The MPI Sei and Punto 75 intake manifold stud patterns are the same, so fit the engine whole. Use the MPI Sei intake manifold.
The exhaust will just clear the driver's side driveshaft rubber boot without modification, but if you can get it altered a little more clearance will help. There's no joint on the front pipe like the SPI car, so you can't just fit a spacer - there isn't anywhere to put one!
The 1108 MPI Sei has a knock sensor - the Punto block doesn't have a hole to bolt it to in exactly the same place, but about an inch or two further down there is an unused threaded hole (probably from the Punto's alternator mounting bracket) which will do.
Cam drive. The 1108 MPI has a different pitch belt to the Punto 75, and also a knobbly bit on the inboard edge. This knobbly bit points at the cam position sensor, which is what the extra bit with the wire on next to the oil filler cap is. So you need to use the Sei crank pulley, water pump and cam pulley - and a belt from a newer mk2 MPI Punto 1242 8v. Oh, and the Sei cam cover complete with sensor.
You will also need to use the Sei's water rail on the front of the engine, the Punto one exits at a different angle.
Mounts, gearbox, starter and alternator from the Sei can be retained. The flywheel, clutch friction and pressure plates from the 75 and Sei are the same, but the Sei release bearing is different.
I have a few questions...
Has anyone on the forum done this conversion into an Mpi Seicento?
With regards to the wiring loom and ecu, what am i going to need? Is the loom the same? Can i use the standard ecu or will i need a 75 ecu, if so what probs will that cause with transponders etc...
Are these engines pretty easy to get hold of? and how much should i be looking to pay for one, and the other bits needed.
All information greatly appreciated!
There are no sheep in the city....
Rosso83 is offline Reply With Quote Quote
Old 02-03-2008   #2
Greece
Re: Punto 75 mpi conversion
Here in Greece, there is a MKII Sei that runs on Punto75 engine. He uses both ECU's, Punto 75 ECU for engine management (front harness) and Sei ECU for the rest.
1242cc, IHI RHB3 turbine, MS-II running MS-II/Extra 3.1 Final Release
Asteris is offline Reply With Quote Quote
Old 02-03-2008   #3
Ive did the conversion on my car almost 2yrs ago. The wiring loom is exactly the same so you dont need to touch the ECU. The only minor difference is theres a knock sensor which doesnt have a fitting on the 1242 so you will have to hide it somewhere solid, no big deal.
These engines are everywhere. Go to your local scrappy or do a search on parts gateway, they will get you loads of quotes for the engines. You shouldnt be paying much over £120 for the full engine with around 30000 on the clock. Ebay is also thriving with the engines at bargin prices.
Any other questions just ask.
Thanks Rosso83 thanked for this post
rich_lufc is offline Reply With Quote Quote
Old 02-03-2008   #4
kritip's Avatar
Trader Rating: 4
kritip has donated!
Quote Originally Posted by Rosso83 View Post
That means you currently have an SPI? If so its not a straight swap. I'd just use the 75 code box and ecu. You will need to trace a lot of wires to join though.....or go aftermarket.
I'm not so sure that converting spi to mpi ECU wise is that easy. I have heard one or two do it, but no real details, and not sure how well it works.
Kristian
kritip is offline Reply With Quote Quote
Old 03-03-2008   #5
I thought he meant sei mpi to punto 75
Old 03-03-2008   #6
I do, i have a phase 2 MPI Seicento, and want to fit the punto 75 MPI lump.
So its a case of taking inlet and exhaust off, swapping everything over following the above guidelines, and retaining 1.1 ecu?
With regards to the release bearing being different, do i need to change that or will it work?
120 for a 30,000 sounds like a bargain, looks like its going to be cheaper than i thought.
Old 03-03-2008   #7
Trader Rating: 5
fingers99 has donated!
If you're keeping the Sei gearbox, keep the Sei release bearing. The engine change would be a good time to pop on a new clutch.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 03-03-2008   #8
im doing this conversion.
in the middle of re building my 75 engine back up now, completely stripped down just to make sure every things sound. so hopefully going to put it in my seicento schumacher middle of next month, also got gt front brakes to go on.
PuntoMK3 is offline Reply With Quote Quote
Old 04-03-2008   #9
Take some pictures! I would greatly appreciate any tips or things to watch out for when you do yours, I've just begun the sourcing of mine.
What markings/numbers will be on the 75 lumps and where will i find them?
Old 06-03-2008   #10
Rip'n'Burn
Smiler121's Avatar
Trader Rating: 4
Smiler121 has donated!
Quote Originally Posted by rich_lufc View Post
What did you mean by "hide it somewhere solid"?
That which does not kill us makes us stronger!!!
Smiler121 is offline Reply With Quote Quote
Old 06-03-2008   #11
At first I taped it to the underside of the battery houseing but it does have a handy hole through which you can attach it to a spare stud within reach of the knock sensors wire. Ill see if I can get a pic of what Ive done with mine as I cant quite remember.
Old 06-03-2008   #12
Trader Rating: 5
Alternatives are the alternator bracket or, there's a boss below the place where it should go which can be tapped.
M12 fund 20
Old 06-03-2008   #13
kritip's Avatar
Trader Rating: 4
kritip has donated!
Down point is the ecu will actively advance timing , based on knock, to ensure better combustion and emissions. If the knock is not working properly, it may advance and due to no knock feedback you will get knock.
Its not going to be drastic...it is a factory fit ecu....but its not that good for the engine.
bolting it anywhere on the block is better than where you put it
Old 07-03-2008   #14
Trader Rating: 5
Are you sure it does advance the timing? If it did, I'd expect more performance on 98 octane. My Sei runs no better/faster on it.
M12 fund 20
Old 07-03-2008   #15
Mine neither, though in theory it should. Seems I'm spoilt for choice on 75 lumps, so I have the luxury of being very picky.
The original article suggests using the alternator bracket, seems like the best way to go.
Thread Tools
(G) How many Puntos are there on the Forum? - The Thread FiatStiloJTD Punto (Mk2/2b) 543 06-06-2008 17:15
