Rosso83
It's time I put a bit more poke into the Sei, after reading the following in the FAQ's ive more or less decided this will be the easiest, cheapest and best bang for buck conversion for me.
I have a few questions...
Has anyone on the forum done this conversion into an Mpi Seicento?
With regards to the wiring loom and ecu, what am i going to need? Is the loom the same? Can i use the standard ecu or will i need a 75 ecu, if so what probs will that cause with transponders etc...
Are these engines pretty easy to get hold of? and how much should i be looking to pay for one, and the other bits needed.
All information greatly appreciated!
The MPI Sei and Punto 75 intake manifold stud patterns are the same, so fit the engine whole. Use the MPI Sei intake manifold.
The exhaust will just clear the driver's side driveshaft rubber boot without modification, but if you can get it altered a little more clearance will help. There's no joint on the front pipe like the SPI car, so you can't just fit a spacer - there isn't anywhere to put one!
The 1108 MPI Sei has a knock sensor - the Punto block doesn't have a hole to bolt it to in exactly the same place, but about an inch or two further down there is an unused threaded hole (probably from the Punto's alternator mounting bracket) which will do.
Cam drive. The 1108 MPI has a different pitch belt to the Punto 75, and also a knobbly bit on the inboard edge. This knobbly bit points at the cam position sensor, which is what the extra bit with the wire on next to the oil filler cap is. So you need to use the Sei crank pulley, water pump and cam pulley - and a belt from a newer mk2 MPI Punto 1242 8v. Oh, and the Sei cam cover complete with sensor.
You will also need to use the Sei's water rail on the front of the engine, the Punto one exits at a different angle.
Mounts, gearbox, starter and alternator from the Sei can be retained. The flywheel, clutch friction and pressure plates from the 75 and Sei are the same, but the Sei release bearing is different.
