If you browse my 1242 16v project, i used the sei 1.1 mpi ecu driving all of the 1.2 16v engine just fine. Ran for many many thousands of miles without even a remap. Have to extends a few connectors and wires though.
It will be even less of an issue driving an 8v mpi engine
Just drop the whole 75 setup including the fuel rail and 75 injectors in.
75 injectors flow more than the sei mpi injectors so should be used. i kept the 16v injectors with my sei ecu, and they flow even more cc/min.
My motivation was the same, the code issue was easiest sorted by using the 1.1 ecu
Now I run aftermarket ecu though, as its far more tuneable.
JR also still runs a 1242 16v on stock sei mpi ecu, and has had his remapped to get more power, so its been done by a few and works fine.
My 1242 thread is in my sig, may be worth a skim read, sure theres some useful stuff in there regarding the ecu.
Kristian
