I'm wondering what the highest revs a standard 1108 block
can be taken to regularly without becoming unreliable as i
think 6000rpm is not high enough to make decent power.
Insurance costs rule out slotting in a 1.2 engine
The only way of making real power at that kind of engine speed is to put in a lumpier cam
port the head.
You might need a close ratio or even a 6 speed box.
cool so without the balancing you would not go to 7k?
what duration is the cam to be peaking that high
so is the limiter set to 7200 as standard then?
Brooky's car has just one throttle position and even if it reved to 15k it still wouldn't be enough
Have you tried getting quotes for a 1.2 conversion from modified car specialists? My tuned Sei sporting, Cinq sporting 1.2 8v & a Cinq 1.2 low boost were all within 10% of each other to insure, the difference between them was the security, replacement costs of the cosmetics and the car values.Insurance costs rule out slotting in a 1.2 engine
