ronnieronson Bring On The Trumpets! Joined Feb 6, 2007 Messages 1,464 Points 347 Location Hull Feb 21, 2008 #1 http://www.obdkey.com/vehiclediagnostics.asp Looks interesting... anyone seen / tried / own one?
R randomizered ' Parked in the garage Written a guide Joined Feb 16, 2005 Messages 5,983 Points 988 Feb 21, 2008 #2 I've got an elmscan and it worked great You can do quarter mile runs, 0-60, read and clear codes, check rpm, coolant temps, datalogging and LOADS more Mine is now no use as i removed my ecu for MS lol. Kristian
OP OP ronnieronson Bring On The Trumpets! Joined Feb 6, 2007 Messages 1,464 Points 347 Location Hull Feb 21, 2008 #3 kritip said: I've got an elmscan and it worked great You can do quarter mile runs, 0-60, read and clear codes, check rpm, coolant temps, datalogging and LOADS more Mine is now no use as i removed my ecu for MS lol. Kristian Click to expand... prospective pm sent
OP OP ronnieronson Bring On The Trumpets! Joined Feb 6, 2007 Messages 1,464 Points 347 Location Hull Feb 21, 2008 #4 Lol - just looked the elmscan up... sounds good, not quite what I'd be ideally after, but good nonetheless. Is there any device out there with a mini lcd for programmable on the fly readouts? I like the OBDkey as I could sync it over bluetooth with some java software on my phone... again not ideal, but workable methinks....
R randomizered ' Parked in the garage Written a guide Joined Feb 16, 2005 Messages 5,983 Points 988 Feb 21, 2008 #5 No worries I'd try and steer clear of BT one's though. Heard bad reviews about them, various different makes as well. Kristian
