1242cc's in!
It wont start mind.[!]
Its turning fine on the motor but its not actually firing itself under its own steam. eg: Turn ign, it splutters and tries to start, stop turning, engine stops.
Could any of the following have a bearing on this:
1. Earthing esp. Starter Motor, (the earth is connected to the top of the head, to the same bolt that the HT coil cover's connected to. Its turning OK, so Id say this is not an issue really
2. Timing (I have a feeling that I may have set the timing incorrectly)
3. Cam follower shim thickness set incorrectly (Havent checked them yet)
Admittedly, there is little to no fuel in it, so i'll get some later and try again, but all the sensors worked fine beforehand
Oh, how do I know that the alternator drive pulley (the crank sensor thing) is set correctly? I think I put that on OK (I marked it beforehand). Also does 1 full turn of the crankshaft pulley give 1 full rotation of a piston?
Tom (AofB)
95 Cinq Sporting - Rattly GrpN Catback Exhaust, <font color="black">Buckets</font id="black"> and 3pt Harnesses,Sexy VW styleé dials (that look great, but dont work!! D)), 10" Sub and 6x9's, ETech Wing. Lots of Dirt!
1242cc Engine in car, not starting, boot delock soon, K+N still in garage!
Tom (AofB)
