Thread Tools
Old 06-02-2008   #1
help. Cinq top radiator hose keeps bursting
899cc
Hey all...
I've been through 2 top hoses in 2 weeks. I suspect either a blocked thermostat or blocked radiator. After a drive (only 5-10 miles or so) the top hose would look very swollen, like a fat sausage.
any help would be massively appreciated.
thanks
reuben
oliversteele is offline Reply With Quote Quote
Old 06-02-2008   #2
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: help. Cinq top radiator hose keeps bursting
Excess pressure should vent through the cap. If there is excess pressure, where is it coming from? Possibly time to run the car with the cap off to see what happens. I presume you did bleed the system after you fitted the new hose.
D
Old 06-02-2008   #3
when i released the radiator cap the swelling in the hose went down as the pressure was release through the reservoir.
bleed the system. hmmmmm. after attaching the new hose i ran the engine with the rad cap off until the level stopped dropping in the reservoir and stayed at the maximum marker. where are the proper bleed valves?
Old 06-02-2008   #4
Autotest Special
rallycinq's Avatar
Trader Rating: 1
One behind the drivers side headlamp, assuming RHD, the other, if fitted, on the bulkhead leading to the matrix.
D
Old 06-02-2008   #5
ok thanks. i'll try yet hanother hose with a new rad cap (and a proper bleed) - before i move onto new thermostat and new radiator. I guess that's the most cost effective way round.
Old 06-02-2008   #6
Trader Rating: 5
fingers99 has donated!
Does seem pretty extraordinary!
Can a radiator really block that badly?
Might be an idea to run a compression test on it.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 09-02-2008   #7
Greece
the same thing hapend to me when the head gasket was blown
georged30 is offline Reply With Quote Quote
Thread Tools
(G) how many cento owners custard Cinquecento / Seicento 87 12-08-2014 11:48
