theresmallbutcheeky
need help when i put my handbrake down the light still stays on is there any solution to this iv pushed it down to the max.
Sensor stuck, frayed cable............
Glad you're not about to die
ok sorry for the trouble im doing a vote whats better imo blue and orange sporting or yellow sporting
ok calm down the brake fluid is fine.
How do you use the tes facility ? I never knew how to do it !!!
Ideally you should check your brake fluid every week anyway and not rely on dodgy sensors...
well i had this problem with mine, i changed the front disks and pads and the light never returned again
not much help to you but thats my experience
well i cant say my cars run through a red light because of brake failure?
what with the oh dear? i had them changed as i they started to squeel, one of the pads had completely worn down, after they were changed the light went off and the braking was much better?
It's just the attitude that gets me. You run the car till one of the pads is bare, then the warning light mysteriously goes out when you change the pads and disks!
To me it indicates a car that simply isn't maintained properly and an owner who doesn't care a lot for other people on the road or himself.
