Old 21-01-2008   #1
Clubcento Member
CaneyJ has donated!
Turbo Fuelling in West Mids
Hi all; well have had a little problem with my cinq. 800 miles after the conversion the lambda sensor has given out which has prompted me to sort out the fuelling issue.
I believe the car runs rich top end which is why I believe that the final fast run I did killed the sensor so am looking for a place in the West midlands that knows how to set up a low boost turbo cinq using the Van Aarken equivalent of an Aquamist MF2 injection controller.
CaneyJ is offline Reply With Quote Quote
Old 21-01-2008   #2
arc
this is where i stand
arc has donated!
Re: Turbo Fuelling in West Mids
i don't know of anywhere off hand.. but why west mids - your location says surrey??
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 21-01-2008   #3
Trader Rating: 5
fingers99 has donated!
You sure it's not an ordinary MF2? Anyway, Chris from 1320 Autos has a lot of experience setting these up, although it's not really the West Midlands, but nearer Silverstone. If you want real, black country, West Midlands, you could try Aldon Automotive. A Google will find them.
M12 fund £20
fingers99 is offline Reply With Quote Quote
Old 21-01-2008   #4
kritip's Avatar
Trader Rating: 4
kritip has donated!
Is it a standard lambda or wideband....regardless, a few thou of rich should be ok...at least to 11 AFR which is RICH!
Hos location says worcs to me...that near wales isn't it? Not checking and may look like a dumbass here hehe
Kristian
kritip is offline Reply With Quote Quote
Old 21-01-2008   #5
Clubcento Member
CaneyJ has donated!
Sorry yeah just updated it he he, arc was right before. Moved to Worcester a couple of months ago. Was just a boggo lambda that gave out but it hasn't been changed in the life of the car so 10 years is ok going I guess.
It might have gone via natural causes though knowing turbos and the crude fuelling system it was probably clogged out. Even so, the occasional whiffs of petrol hint at occasionally running rich and it needs to be done properly anyway (Iíve already checked fuel lines and itís not them).
When I made the kit I had a friend come and give it a reasonable tune up. He had a proper battery backup wide-band lambda which we plugged into a 2nd port I had put into my new downpipe and just mapped it roughly by driving around in a variety of conditions but it's not perfect.
Have noticed on motorways for instance it can sometimes hold back on acceleration and I need to dabble the throttle to make it wake up so it is also running lean at times.
Old 21-01-2008   #6
Trader Rating: 5
Really needs a rolling road. Talk to Chris at 1320 -- he's doing Jamie's Sei turbo on Monday and has done all Aaron/Emma's cars.
M12 fund £20
Old 21-01-2008   #7
J333EVO has donated!
As said Jamie hi-boost Seicento and Emma & I with her 1.4 16V Seicento will be going over to Chris 1320 Autos on Mon at about 11am to do some power runs and checking the settings of the MF2 on Jamies car, plus check over all the settings on the Emerald on Emma's car now that it is properly run in, plus have some fun at the same time & you are more than welcome to come along.
PM me for more details, phone number etc, if you would like to come along. I would recommend that the fuelling is done ASAP as it will only lead to many other issues.
Aaron.
Cinquecento Abarth 1.4 16V 6speed track toy
Lancia integrale EVO1 Homologation model
MINI Clubman Hampton Edition Cooper SD
VW MK5 Golf R32
J333EVO is offline Reply With Quote Quote
Old 21-01-2008   #8
its a different mf2 too what we run anyway and mine runs one of the wierd ones :P shouldnt be any different to setup though should it?
Van Aaken High Boost Turbo Cinq In Caribean Orange, Highly Modded
Whiley is offline Reply With Quote Quote
Old 22-01-2008   #9
Clubcento Member
CaneyJ has donated!
Likewise to your's, mine isn't really an MF2. It's based on one but was built by Van Aaken and branded as a TFC1 and has a built in 2nd Lambda sensor. Iíll enquire with 1320Autos and see if they can fit me in with you .
Old 22-01-2008   #10
Trader Rating: 5
Quote Originally Posted by CaneyJ View Post
Likewise to your's, mine isn't really an MF2. It's based on one but was built by Van Aaken and branded as a TFC1 and has a built in 2nd Lambda sensor. .
Pics of this wierd device (not that an MF2 isn't wierd!) would be interesting!
M12 fund £20
Old 22-01-2008   #11
I Need Beer
allanhelen's Avatar
allanhelen has donated!
There is a "normal" MF2 close to ending on fleabay right now just in case anyone is after one
No FIAT's any more and nothing else sensible either
allanhelen is offline Reply With Quote Quote
(G) Punto 1.8 HGT - Turbo Kit/Eaton Supercharger/ 16v Turbo Coupe Engine?? Mooks Punto (Mk2/2b) 29 11-03-2014 13:59
Ten of the Best? alainax Leisure Lounge 16 04-08-2006 01:03
(S) Uno MK1 Parts? Dima Uno 3 15-08-2005 11:00
(G) tipo DGT + uno turbo i.e. possible???? ShaunBurford Uno 10 08-07-2004 22:39
