General Lost the alloy wheel bolt!
near Great Yarmouth
My Cinq Sporting has the standard alloys, I've looked all over but can't find the locking nut adaptor.
Is there a simple way of removing the wheels or will most garages have the correct tool? There's a few local places which sell alloys so is it possible they'll have a tool for the job? :cry:
I've heard of people drilling out the bolt but surely this could damage the wheel? :confused:
I presume you've looked in the spare wheel area in the boot? And in the little tray under the passenger part of the dash? Both are possible places and not imediatly obvious.
As for removing them, there are special tools for the job, if you ring up your local tyre fitters first they will tell you if they have the tools and how much they will charge.
Yes i've taken everything out of the boot and even looked in the ashtray in the rear door card but nothing. :cry:
So there is a tool which some garages might have? That's good news as I didn't fancy drilling anything.
Why do you bother locking your car because people can still break into it. Its all about a deterant, making it harder for the thief. And I'm sure many people are glad you can get these, otherwise you loose a locking key and you are screwed.
And yep, they come in 'kits' so you can choose the nearest one to your locking nut.
get a 17mm socket and hit it on with a hammer. untighten the bolt until its doable by hand and then wiggle the 17mm socket free from the bolt (alot easier to do whilst the bolt is still in the wheel).
With the amount of hammering i did on mine,i put the bolt in a vice and hammered the socket off again. It would never of wiggled free(y)
Or if you've got a socket set with a load of imperial sockets as well (measure in inches rather than mm) then try hammering on one of those. That's woked for me in the past and it saves buggering up a decent metric socket (y)
