Old 24-10-2007   #1
Oil leak (Rocker gasket?)
Hi, i have recently bought a 1998 fiat sei 1.1 abarth, it is a pretty tidy car except there is oil of somesort leaking from two places. (or could just be one but making two puddles).
One runs down the gearbox side of the sump and makes a mess of the sump, i have researched to try to fully understand and the most common answer was that the rocker cover needed replacing, is this correct?
The other appears to be coming from the gearbox itslef, and i could not find a conclusive answer, any ideas?
I will clean the oil and try to find where it is coming from tomorrow when there is light.
Any help would be much appreciated.
_Sanchez_ is offline Reply With Quote Quote
Old 24-10-2007   #2
Trader Rating: 1
cc1 has donated!
Re: Oil leak (Rocker gasket?)
Fiat have redesigned the cam cover gasket and works alot better.
The gearboxes tend to leak oil out of the breather on top.
cc1 is offline Reply With Quote Quote
Old 26-10-2007   #3
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Check the oil level in the box, the hole is in the front face.
Smell the oil in the box and try to match the smell from the leaks to see where your second leak is from.
D
Old 26-10-2007   #4
Xen has donated!
or feel the thickness. There should be noticable difference between engine and gbox oil.
Xen is offline Reply With Quote Quote
Oil Change bhinderharminder Leisure Lounge 8 26-03-2009 14:51
(T) 1.4 Turbo engine oil leak Blue MK2 Uno 3 15-09-2007 11:18
(T) Mk1 Oil Leak SeicentoKev Punto (Mk1) 3 31-08-2007 00:36
(T) Oil leak somewhere lower cam belt cover leedssilvercinq Cinquecento / Seicento 1 12-12-2006 21:30
(G) oil leak under car andy dowds Panda (Classic) 9 30-08-2004 08:54
