General cinq cold start misfire
bhola
problem with my cinq sporting misfire?
Hi Guys,
i've been having a problem with my cinq sporting for the last couple of days.when i start it from cold its got a misfire and feels like its holding back and popping,but soon as its warm she runs fine.Any ideas???????Cheers.
Re: bhola
Had a service recently? Checked all leads and plugs/pipes to see if a leak?
You wouldve helped yourself get more replies if youdve put it in the right section and put a relevent title :rolleyes:
Seicento misfire
Hi, I've got a Mk2 Sporting which seems to misfire on these cold mornings. The warning light that looks like an engine comes on after a couple of miles after the "choke" goes off. Plugs are new & I changed the thermostat. Problem clears after 3 or 4 miles.
Re: problem with my cinq sporting misfire?
My Sei does this when the HG fails (yes that is plural, it's getting to be a regular occurrence ). My Punto used to do this when cold, especially when it was freezing, it was never really diagnosed and solved properly as it never happened after a remap. The only hint was the ECU seemed to learn this habit as if you reset the ECU it didn't happen.
