Technical do you know your engine mounts??
my car appears to have the mount in the second picture.
I have never seen a car with the first type mount....but that is the one listed for my car :confused:
The one it looks like i have is listed for spi only ... however the spi is listed as taking both mount types?!
these are all for the 1108 versions.
Has anyone seen the first mount type in the flesh? is it interchangable and is it better?
The first one looks like it will give me less issues with the alternator belt that I'm fitting, but it a fair few quid, and can't return custom orders :(
Kristian
My car is listed as an M3 so will check the mount in the morning.
In the first drawing, Part 2 will be an adaptor plate which probably requires threaded inserts in the chassis section for it to fit and may be used for cars with Air-Con?
The second picture mount is listed for the cinq also.
Mine is picture 1 M3 MPI type. M2 is SPI type.
Punch your chassis number in the eper and it should then only give the parts for your model..ie: 00xxxxxx under vehicle data.
