Technical cinq engine missing
aljo
hi there wonder if anyone can help. I have a fiat cinquecento m reg 899cc which has no spark on one cylinder, i tryed new leads and plugs, but no difference, if i swap over the coil leads ( small wires from ecu ) the problem swaps to other cylinder. someone told me it could be the ecu? i have found many ecu's at scapyards but dont have exactly the same numbers on them. have found one on ebay that is nearly the same. can anyone help please.
OK, so its a very early one that will have no immobiliser in it. Strangely enough I might be able to help, but I will need to PM you.
The moderators get sniffy about selling stuff on the general forum (quite rightly too I might add)
D
so on the ecu's do all the no have to match? will it need to be reprogramed or can i fit it straight in
ok the one i have coming seems to have most the same no's
