shnowzy
Member
I have been looking at this device on the net claiming 25% increase in milage
http://www.wyominginstruments.com/gas_home.htm
what it says it does is [:0]
petrol is fed to the Fuel Atomizer from the fuel line.
Crankcase gasses are passed through the Fuel Atomizer.
Sludge from the fumes is separated and collected in the sludge chamber.
Liquid gasoline is turned to vapor petrol as it travels from the Fuel Atomizer and is then injected into the intake manifold.
The liquid petrol passing through the present fuel system is decreased to compensate for the added vapor gas
question is how do i fit this to the cinq sx
specific questions r does the cinq sx have a pcv valve?
does it have a CVC line or a vacuum line that runs from the crankcase to the intake manifold?
do cinq's have a valve on the fuel rail under car near pump i think
please take a look at this link and see if i will have any trouble fitting this device
http://www.wyominginstruments.com/g_inst.htm
any help would be much appreciated results to follow when its fitted
further question is A the fuel feed and B return fuel pipe
and would C be the pipe that returns the unburnt fuel or would that be D as that one goes back to the trotle body
