My brake fluid's two years old so I've been trying to change it. I did two wheels fine, but one of the bleed valves rounded and I can't get it to budge. Eventually I decided to replace the cylinder, which so it wasn't the end of the world. I dismantled the brakes and tried undoing the brake pipe... that's rounded as well now!
I refitted the brake and I've got to do the whole job again. It was supprisingly difficult to find somewhere that sells brake pipes, but I found a local place that made one up for me. Got a few extra tools which may help too. So when I get chance I'll have to replace that too. I'm hoping that the other end of the brake pipe doesn't round off too.
I remember a couple of years ago the bleed valve actually snapped off, but the brake pipe came undone reasonably easily.
Have you guys ever had similar problems? Is it common on these vehicles? It's only the rear ones that have the problem, the fronts were fine. I wonder what would have happened if I got the car serviced at a garage, I suspect they just wouldn't bother bleeding the brakes.
