General My MPG?
General My MPG?
Corby, Northants
hi there, hopefully someone can help, I was wondering what should my MPG be now that the engine change is done roughly?
specs are:
1242 8v, P75 cam, Tricker 40mm TB, BMC CDA induction, Mckcrich chip, Supersprint 4-2-1 manifold, Supersprint backbox, De-cat and no centre silencer.
many thanks in advance :)
Lenny
With the following i was getting 33mpg out-right thrashing. 50 mpg driving like a granny.
By thrashing i mean into the red in 2nd to 4th.
1242 8v, P75 cam, Tricker 40mm TB, BMC CDA induction, Mckcrich chip, Supersprint 4-2-1 manifold, Supersprint backbox, De-cat and no centre silencer.(Novitec airbox)
1242cc 8v SPI, GSR test induction, 30mm throttle body, ported and flowed head, skimmed to factory rec. max. level, metal head gasket, Supersprint back, box and spacer. Otherwise standard sporting incl. cat.
Running on Tesco 99 between 47 and 51mpg before mapping (76bhp) and after mapping (80bhp) about 2mpg down.
can't fill it to the brim :eek: petrol comes out of the fuel cap when i first put a tenner in :eek: have searched about it and guess it's a blocked breather hose from what I have read? Need to take a look for it and see if it's blocked, also when the fuel cap is taken off, should there be like a spring return cap underneath which is pushed out of the way when the petrol pump snout goes in, and then snaps back when you pull the snout out?
Also, just back from the mrs house, clutch making a bit of a rattle until it is depressed, need to do a slight adjustment on it tomorrow.
Thanks again
Lenny
You'll find its easier to calculate your MPG if you put a fixed amount of fuel in, say 15 litres, rather than a fixed amount in terms of cash. This then prevents any slight variations in price from different suppliers, or different grades of fuel from affecting the results.
Just my 2p worth.
Lenny will try catch you on msn, but if you're out banbury way again anytime soon i'd take a look for you if wanted? :) though pretty busy most weekends atm :( (and not really got any spare sensors to try as gave away my last spare map sensor not long ago :()
