Thread Tools
Old 14-07-2007   #1
Trader Rating: 3
Rear drum removal
I've embarked on sorting out the partially seized handbrake & am having a right nightmare trying to get my drums off. I've disconnected the handbrake cable and given the arm a few whacks with a rubber hammer, this means I can actually now just about turn the road wheel by hand. There is about 10mm of 'slack' but stiff movement in the lever now, but I can't for the life of me get anywhere with removing the actual drum. I've tried drawing it off with bolts but to no avail .
Any other hints from people?
GoBe is offline Reply With Quote Quote
Old 14-07-2007   #2
Trader Rating: 10
dave has donated!
Re: Rear drum removal
3 leg puller
Old 15-07-2007   #3
Trader Rating: 1
hit it with an hammer!!!!!!!!!! a big one
Brooky is offline Reply With Quote Quote
Old 15-07-2007   #4
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Quote Originally Posted by Brooky View Post
Ah, the 'Universal Adjusting Tool, Mark 1'
D
Old 15-07-2007   #5
arc
this is where i stand
arc has donated!
i think i wedged a big screwdriver between the drum and plate and then lightly tapped it with the mark 1. i had no intention of reusing any bits from those brakes though..
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 15-07-2007   #6
Trader Rating: 3
*sigh* I want to have brakes at the end of it that
thanks for the suggestions dave & Arc.
Old 15-07-2007   #7
kritip's Avatar
Trader Rating: 4
kritip has donated!
A hammer driving from behind, with a stake or screwdriver should help shift it, if you don't have hub puller....but its def wise to get one in the tool kit...I have even used mine for breaking ball joints
I am surprised it so hard to get off though...good luck with it
Kristian
kritip is offline Reply With Quote Quote
Old 15-07-2007   #8
hi friends :waves:
Liam's Avatar
Liam has donated!
Try and use a wooden pointed object cos hammering it with metal can shatter the drum.
Liam
Yes it's really me!
97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND
Liam is offline Reply With Quote Quote
Old 16-07-2007   #9
scottyJTD has donated!
I have never seen the chinq back drum,but when i done my brava,i had the same problem
What i done was take away the wheel baering nut and washer CAREFULLY
And then took the hole hub with the drum on it of,it just slides of
Then turn the drum over and gently chap the hub out of the drum carefuly
and then put the hub back on be careful to keep the baering intact.
Scotty
scottyJTD is offline Reply With Quote Quote
Old 16-07-2007   #10
Trader Rating: 3
Drums are off rubber hammer and a puller did the trick, turns out the inside of the drums were all rusted up so off to work and machined out the insides and they're all shiny again.
However the split pins are so rusted in I can't get them out , I think it's time for a few pieces and a jr hacksaw
Old 16-07-2007   #11
Trader Rating: 1
Quote Originally Posted by kritip View Post
Size:  1.8 KB lol
Thread Tools
(T) A handbrake which works! (Guide) circolo Uno 1 01-06-2007 17:06
(T) Rear quarter window removal GoBe Cinquecento / Seicento 7 24-12-2006 12:15
(S) Updated price list 21/04/2004 Body Stylist Punto (Mk1) 30 09-04-2005 17:02
(T) Rear window removal / fitting Dan Cinquecento / Seicento 10 13-11-2004 18:12
(G) DJ Bucho is back DJ_Bucho Cinquecento / Seicento 19 14-05-2004 18:41
