stiglou
New to looking under bonnets. Bought a Cinq Sporting about 7 months ago, apart from a new clutch and requiring new headlamps to be fitted to pass MOT the car is very popular. Current problem is after car came back from having new headlamps fitted the electric windows don't work, I checked 7.5amp fuse (LHS of box below relay), fuse is fine, I popped off door panel and used multimeter to test wires to window electrics, no power is getting this far. I plugged multimeter into the fuse slot, no power here either, I can see purple and white wires going up to deep behind the dash, I've got an owners manual on order, any suggestions before I take the whole dash out - is there a connection point under the bonnet somewhere, should I be looking under the battery? Any help much appreciated. Stig (& Lou)
