wkd cinq
Member
does ne 1 no how 2 tak out the bak window
of a cinq?? an wil i fuk up the seal??
This is just what I was looking for. I'd like to take the rear window out of Julio so I can respray the tailgate and tint the glass, but i was concerned that it was bonded. Am I right in reading this that the glass is held in by the rubber only, and so should be able to come out, get tinted, and be replaced without any of that hassle? It would be great if it could. It seems you're saying extract the glass from the outside of the tailgate, is that correct? Thanks for your info, it's a big help.Originally posted by max
.....should take no more than 60 seconds!
This job is a lot easier to do on a hot day,.......... Open the boot so that the tailgate is fully up, get a strong spatula ........ Carefully hook under the rubber in one of the corners whilst applying a firm but not forcefull pressure on the glass with your hand ........Whilst gently pushing the glass (use a cupped hand, rather than flat) follow the rubber and hook it over the lip of the bodywork. ....... Hope this helps. .
