Andi1985
Just wondering when you guys would change gears like at 3000rmp or 2500rmp etc... just would be instresting to know and at what rev count would be the best to change gears??
Andi
Andi
If you wana get really technical take it to a rolling road and get a thrust v's road speed graph made up of all the gears. back work the cross over points from gear to gear from speed to rpm & you're sorted.
ACT on co2 said:Using your gears wisely by changing up a gear a little earlier can also reduce revs. If you drive a diesel car try changing up a gear when the rev counter reaches 2000rpm. For a petrol car change up at 2500rpm.
source
So if your own about changing gears for reducing emissions... thats what the government are recommending.
co2 is not a considerable greenhouse gas, and does not cause global warming.. so please don't post that crap in here!
Agreed, it's too gutless to change at 2.5K when pottering2500rpm in the cinq.. no thanks. 3000rpm is the sweet spot for pottering about if you ask me.
