Stuartl Maranellohouse.com Parked in the garage Joined Aug 2, 2004 Messages 2,272 Points 487 Location Northern Ireland May 22, 2007 #1 New to this but do work on cars. Was wondering if anyone has changed one as the one we have in is leaking and needs done.
A arc this is where i stand Parked in the garage Joined Oct 8, 2003 Messages 19,719 Points 3,335 Location Manchester May 22, 2007 #2 as far as i know easiest way to remove it is to very lightly screw a couple of small screws into it and then pull it out. new one simply slides in with a few whacks from a suitable drift.
OP OP Stuartl Maranellohouse.com Parked in the garage Joined Aug 2, 2004 Messages 2,272 Points 487 Location Northern Ireland May 23, 2007 #3 Well that's straight forward enough. Thank you
R randomizered ' Parked in the garage Written a guide Joined Feb 16, 2005 Messages 5,983 Points 988 May 23, 2007 #4 Wouldn't it require the removal of the timing belt, alternator pulley, crank pulley etc.? Not a quick job tbh, never done it myself though. Kristian
A arc this is where i stand Parked in the garage Joined Oct 8, 2003 Messages 19,719 Points 3,335 Location Manchester May 23, 2007 #5 yeah, or the gearbox, clutch and flywheel if its the other side.
OP OP Stuartl Maranellohouse.com Parked in the garage Joined Aug 2, 2004 Messages 2,272 Points 487 Location Northern Ireland May 23, 2007 #6 It's the timing belt side. The belt etc does have to be removed but I was just wondering if the seal was an easy out job like others I've done. Thanks guys
