Thread Tools
Old 12-05-2007   #1
Oil Pressure Warning Light problem
We've got a Fiat Cinquecento with about 72000 miles on the clock. Just recently, the oil pressure warning gauge has started to come on after twenty minutes or half an hour's driving. The warning light goes out if the engine is revved a bit but this 'solution' don't work too well if you're stuck in an inner city traffic jam, as we quite often are.
The owner handbook says that it's OK if the light comes on after a long drive under heavy load conditions. But neither of these circumstances are applicable here.
The oil pressure switch has been changed, also the oil and the filter, but the problem still shows up. The pump appears to be working OK since the warning light goes out when the engine is revved a bit so I'm stuck for an answer.
Could you Fiat experts provide some advice as to what the problem might be and how to solve it?
Grazie mille!
Alphaville.
Alphaville is offline Reply With Quote Quote
Old 12-05-2007   #2
Trader Rating: 5
fingers99 has donated!
Re: Oil Pressure Warning Light problem
Doesn't sound good. The 899s seem a little fussy about the oil used. I'd try an oil and filter change with a decent 10/40.
fingers99 is offline Reply With Quote Quote
Old 12-05-2007   #3
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
It could be wear in the engine, or wear in the pump.
D
Old 15-05-2007   #4
Is the sensor next to the oil filter for the dash light?
PuntoBaz.NE is offline Reply With Quote Quote
Old 15-05-2007   #5
cm246 has donated!
I had the same problem with my old Uno and I tried everything at the end it was a loose conection of the actual light switch
cm246 is offline Reply With Quote Quote
Thread Tools
(G) ducato campervan oil warning light problem bobian81 Ducato 13 11-06-2009 15:44
(T) automatic Punto's gearbox warning light is on! helen_gemini Punto (Mk2/2b) 21 13-04-2008 11:20
(T) Oil Pressure Warning light (intermittent) OnLyZ Stilo 14 13-04-2007 08:02
(T) low oil pressure warning light Gaz Lear Stilo 2 15-09-2006 16:28
(T) Oil Level Sensor Failure Warning Tim T Stilo 4 13-08-2006 22:11
