FIAT Auto Specialist Team
Thread Tools
Old 23-04-2007   #1
1st gear difficult to select. Clutch cable adjustment needed?
Hello FiatForum.
Seicento Sporting 1999 (T reg). If my Sei is rolling even slightly forward (and occasionally when stationary) then it’s difficult to get into first gear. Other gears are fine. I’m assuming this isn’t normal. Perhaps (hopefully) I just need the clutch cable adjusted as mentioned in FAQ and here?
Might be relevant: sometimes get a slight crunch when going into reverse, yes I am stopped . Clutch cable snapped 6-8 months ago and ended up getting a whole new clutch.
FAQ forum here is a great, although for someone with a 1999 Sei the recalls FAQ makes slightly worrying reading.
Andersh is offline Reply With Quote Quote
Old 23-04-2007   #2
Scandinavian Passion....
StoneNewt's Avatar
StoneNewt has donated!
Re: 1st gear difficult to select. Clutch cable adjustment needed?
Yeah first thing adjust the clutch, I find if the peddle is set back by more than about 2" from the brake peddle it'll cause mischief with the gears but if it's dead level with the brake peddle it's a not totally engaged!
Seicento Sporting, 1.1 8v N/A, Dark grey
Seicento Sporting, 1.2 8v turbo, Yellow
Volvo V70 D5 Sport, 2.4 20v twin-turbo, Black
StoneNewt is offline Reply With Quote Quote
Old 23-04-2007   #3
Thanks for the quick reply . I’ll get it booked in down the garage. Shouldn’t take long or cost me too much by the sounds of it and might make life a whole lot easier. Fingers crossed.
Old 23-04-2007   #4
StoneNewt's Avatar
go to the garage to adjust the clutch? You nuts?... 2x 10mm spanners is all you need. If you open the bonnet and stand in front of the car at the front to your right you'll see a long threaded rod connected to a metal arm. I never get this right but I think that turning the nuts clock wise pulls the rod through the arm tightening the cable and causing the clutch peddle to rise. The rest is adjustment through feel
Old 23-04-2007   #5
Thank you, I had no idea it was that simple. I’ll definitely give that ago. I’m not clear on what “120mm travel measured from pedal to steering wheel base” means?
Adjustment through feel = get correct level, give it a drive, then try a bit each way and see if it improves?
Old 23-04-2007   #6
punto then coupe
h2ypr has donated!
When adjusting it, you should physically see the pedal moving towards you, not the floor. Get someone to watch to make sure your adjusting the correct way.
Ross
h2ypr is offline Reply With Quote Quote
Thread Tools
(T) Clutch Cable pokerface Cinquecento / Seicento 13 01-02-2011 19:32
(T) clutch cable AGAIN!! fimmo Cinquecento / Seicento 10 22-09-2009 03:01
(T) Another Clutch / gear box issue Zimon Cinquecento / Seicento 15 03-07-2005 13:55
(T) Clutch - cable or clutch itself? SnowBord Cinquecento / Seicento 12 13-02-2005 17:18
(T) Clutch cable adjustment. nicholas Cinquecento / Seicento 8 12-02-2003 22:58
